Anybody have a pair of 285/30/19 they need to get rid of?
Check tirerack and see what tires are availale in that size... or you may end up with a mismatched set. Tony & I are both using Pirelli assemtricos... excellent in the dry, but I have no idea about the wet. A 10.5 " rim should handle that size with ease... my 11" width is BEGGING for a 315... the 305 is not quite wide enuff for the rim.
Go look at tirerack for the specs. The difference is pretty small within an "aspect ratio" family. The problem is... with my AWD, I have to very carefully match front and rear diams. And Pirelli doesn't make that size. I'll cross that bridge next year when I need tires again.
