993 Forum 1995-1998
993 convertible top jam
Old 05-15-2007 | 03:00 AM
unionguy's Avatar
unionguy
4th Gear
Default 993 convertible top jam
Hi,
My 993 has the convertible top stuck to the close position but not entirely locked.
I opened it tonight about 3/4 of the way turn the key to the off position for a while and then turned it back on again the close the roof. The roof now closes all the way except for the motors not locking it in place. Also I tried opening it again and nothing happens.
Any body know if the top can be reset? Or how to completely close it manually?
Old 05-15-2007 | 09:00 AM
vjd3's Avatar
vjd3
Check your owners manual; you can operate the latches manually using a screwdriver; there is a recessed hole by each latch. It takes a lot of turns to close the latch.
You could have a problem with the motor that turns the latches in the roof liner, a bad microswitch or a bad top control module, which is under the dash.
Has your car had the warranty update to the latches?
Old 05-15-2007 | 11:45 AM
Slow Guy's Avatar
Slow Guy
Also there's a great deal of info about cab top problems and solutions on this site. Using the search feature will help get your answers quickly.
Old 05-15-2007 | 01:19 PM
unionguy's Avatar
unionguy
4th Gear
Thanks to both of you for your input. I did however forget to mention that the car was on a jack when I opened it I read afterwards in the manual that you aren't supposed to open the roof if the car is not level. Wondering if when I take it down it will work. (still working on the brakes at this time)
And no, I haven't done the recall yet but was planning on getting it in some time this month. I just bought the car a couple of weeks ago and going thru the list of small items to do.
