993 Forum 1995-1998
Headers
Old May 14, 2007 | 11:16 AM
hutch's Avatar
hutch
Default Headers
Looking to loose some weight in the rear end. Has anybody used the Fabspeed header kit or any other that works well?
Old May 14, 2007 | 11:23 AM
David in LA's Avatar
David in LA
Unless your engine's internals are modified, headers don't help much power-wise...but you do get some weight savings. Replacing the mufflers w/Fabspeed Supercups saves 30-35lbs if I recall correctly and there is also some weight savings by swapping the stock cats with high flow cats like the Dach X-cats.
