ac question
ac question
had anybody had this experience with thier ac system? took my sy 993 today and I tried using my ac . but everytime I would press the ac button cold air comes out for 5 seconds then the vent flaps would close and no air would come out. but without ac flaps would open up again. what could cause this? nothing is more anoying than having your ac not working on a hot afternoon
Sounds like your out of vacuum pressure. When you hit a/c, your car goes into recirc mode. What is SUPPOSED to happen is that immediately your vacuum solenoid engages to allow vac pressure to the recirc flap under the dash to pull open the inside cabin air inlet. Then the electric servo slowly closes the fresh air intake. If you have no vacuum to teh inside flap, the air just shuts down when it gets no inputs. Look under your dash right below the CCU and look for a vacuum tube that may be disconnected. For more details, check the DIY I did on p-car for troubleshooting vacuum.
For a quick verification. Turn the A/C Off, fan on high. Just normal fresh air blowing. Hit the recirc button. Does the same thing happen?
