993 Sat Nav Installation - Becker Cascade
I'd give your local Ferrari main dealer a call, the cascade was fitted to the 360. The maps are supplied by Navteq, so you could also try them. I'll see if I can dig mine out there may be a part number or something on it.
You will still need the usa software for the becker if you order from here in the UK, as the FM stepping is different. It's available as I have it. I would still try your nearest Ferrari dealer, for the actual head unit and the USA maps.
cheers for the help on getting the nav wire in, I now have it located in the front panel of the dash (still trying to decide if to completely hide it in the vents)
found the grommet was behind the second gauge in from the left (remember its lhd) managed to get the cable below and routed to the back of the stereo.
thanks again.
thanks again.
I've had aquite a few emails regarding the Ferrari compact flash card that came with my original cascade unit, well I managed to find it, and I've taken a photo with part number etc showing, so it may help some of you USA based guys out. Just to recap that I ended up with a Becker cascade the boxed was labelled with Ferrari stickers and was supplied with a customers 360.
Hope the photos help.
Pezza
Pezza
