Will a 964 RS door panel fit on a 993 and has anyone used Autos International?
#31
hennessy porsche in Atlanta has a set of RSA panels OEM - $480ish each
you have to order the 993 RS panels but they are exactly the same. depending on options
(i ordered the RS no speaker w/ elec windows and they mis made me the RSA panels)
#32
I have a pair of the appbiz ones, I ordered the blank's and covered them with leather- you're almost better off just making them yourself- I'm not really happy with the material they use, it's a common matt-board, like something you cut out to frame a photo.. the issue is that it deforms easily on friction fit things like the window switches.... shameless plug here.. Geoff and I are gonna make a small batch of RS 993 panels out of PE sheet, covered with foam and leather. The leather will have stitch details- PE sheet doesn't absorb water or deform when you put a switch in it- It's light and quite tough- PM me if interested- They will be ready in a month or two-
Coleman.
Coleman.
