White smoke when start up???
Once out of 5 times theres a puff of white smoke on start up,does anyone know what could cause this???
Thanks Will
Thanks Will
Because the engine's cylinders are horizontal, when the piston rings are in certain position oil will seep by during rest, this will cause smoke during startup. I agree w/ Ed that condensation is also a likely cause.
+1 on Ed's explanation
Water condensation is probably the cause
Pierre
Pierre
Addicted Specialist
Is the car your daily driver? If not, it's perfectly normal for a car that's been sitting for days (especially if over a week) to exhibit a bit of a puff. If you get it downwind, the smell of oil in that puff is unmistakable, vs condensation which has no odor. And since you are in a cold-ish climate (though I don't know what it's been like lately for you), condensation absolutely is the norm. Good call on the oil weight ...what viscosity are you using now, and how much oil do you consume (e.g 1 qt/2000miles)?
Edward
Edward
