Royal Purple Redux (Tranny Fluid)
Good morning folks,
I thought I'd report back now that my Tranny has been flushed with Royal Purple. After a couple of cold starts I'm very pleased to report that my transmission feels brand-new. 1st-2nd has been restored to a reasonable throw effort with absolutely no grinding or resistance. The only significant downside that I can report is that the transmission is a bit louder, but then again, I also have the RS single mass flywheel. My previous fill was Mobile 1.
Now all of this said, I suspect that what Callas used in my car was not precisely the same thing that everyone else has tried. Total charge for the Oil was ~$75, and Mike reports that he usually only uses this for heavy-duty track applications, but that he's had good luck using it in higher-mileage transmissions where shift effort is high when cold. I have to say that I agree. So perhaps there is a new formulation out there for Royal Purple or maybe it is simply a "higher-grade" of the brand, but I'm very happy.
cheers,
sean
cheers,
sean
It would be nice to know exactly which RP product you have. You may have seen my post in the past where I indicated that the RP tranny fluid caused a lot of grinding in my gearbox, so I changed it out almost immediately since it just didn't work. (try a search on "cement mixer" LOL)
