993 Forum 1995-1998
Turbo twist 2 wheels
Old 04-06-2007 | 07:39 PM
hy_993's Avatar
hy_993
6th Gear
Default Turbo twist 2 wheels
Can a 18 x 11 turbo twist 2 wheel fit in a 1998 993 widebody? Why does the local Porsche shop tell me that I should not go wider than 285/30/18? Please help!
Old 04-06-2007 | 08:29 PM
Martin S.'s Avatar
Martin S.
Cool Can it fit?
Probably....when you go larger than 285, it becomes more of a challenge to match up the fronts. The rolling radius, front to rear, must be within about 5%. The actual number is in the Shop Manual.
I can see going super wide for the track, but not for the street. But that is just me. A 225 and 285 combo is pretty slick.
Old 04-06-2007 | 09:09 PM
993inNC's Avatar
993inNC
The 11's WILL fit a widebody, I have them on my 4S. The tire size is irrelevant, tire Mfg's call them by those common #'s, but you must look at the actual dimensions of the tire that count. The difference between front and rear rolling is actually 3% (calc. by dividing the rear by the front rolling dia.). You should technically be able to go to 305's or better depending on the Mfg and the amount of rear camber.
Old 04-06-2007 | 09:50 PM
hoggel's Avatar
hoggel
I use the 996 turbo wheels on my 97 C2S with 295/30s on the rear. Be sure you get the ones with the 45mm offset.
The 225/40s on the front are actually a bit taller (~1.5% more rolling dia.) than 285/30s. They are almost exactly the same height as the 295/30s.
Old 04-07-2007 | 12:51 AM
hy_993's Avatar
hy_993
6th Gear
Thanks for all the help!!
Quick Reply: Turbo twist 2 wheels
