Headlight Reflectors
I noticed that the what appears to be reflectors on the bottom of the headlight casing when viewed from the front are discolored (dull with a yellow, dirty cast). I looked at a friends and they are still shiny and silver. I know the headlight assembly comes out as one unit when unhinged in the luggage compartment. Anyone else experience this discoloration problem? If so is there any way to fix it? Can the inside of the headlight unit be accessed and the reflectors replaced? Thanks in advance for any info.
It's the headlight lens that is yellow at the bottom. I had this problem. You can buy new lenses and replace them. Search around and you can find them for $120 a pair.
I thought it was sunset that had the set for $110 but They want $106 per side. I did a quick search yesterday but didn't find the info on the seller. If anyone can chime in with the info, I'd appreciate it, otherwise I'll keep looking in a few days (leaving for a short holiday tonight) and post when I find the info.
Awesome, thanks.
11234: You can either remove the reflectors as advised above, clean them out with alcohol/nailpolish remover or paint them silver. Instructions on removing the headlight lense can be found on the manual. The reflectors simply pop off. Be careful cleaning the chrome reflective cover around the beam as some people have removed the chrome by rubbing too hard. At $110 for the pair and with the pitting that the lenses are subjected to after 10 years, you're better off buying a new set.
Oh, and no, the reflectors are not sold separately. You have to buy the lense.
Thanks to all who responded. Sounds like new lenses are the way to go. I think it will make a vast improvement in appearance. I never cease to be impressed with the information and assistance available for the asking on this forum. I sure hope I can do my part as time goes by.
