993 Forum 1995-1998
check engine / power loss
Old Mar 28, 2007 | 10:08 PM
schwab's Avatar
schwab
Default check engine / power loss
My '95 993 check engine light is cycling on & off every 3-5 mins. Acceleration & power problems also occuring sometimes while the light is on & sometimes when the light is off. What ya think.
Old Mar 28, 2007 | 10:13 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
O2 sensor? - also sounds like misfires from old plugs or bad wires. Also could be carbon tracks built-up inside your distributor cap.
Old Mar 28, 2007 | 10:18 PM
schwab's Avatar
schwab
O2 sensor sounds good to me as I've been suspect as it appears damaged(bent). Just purchased car. Any scoop on self replacement?
Old Mar 28, 2007 | 10:38 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
We use the OEM one; part # 993 606 126 01 as thats a plug 'n play solution.
Chris made an excellent suggestion about misfires; unless you have all the maintenance records about the car, its good practice to replace the ignition parts that generate misfires and running problems. If these cars are allowed to do that for long, the cat temperatures get high enough to melt the core and render it useless.
Plugs, caps, rotors, and wires are all regular wear items and I'd also consider replacing the fuel filter, air filter and of course, an oil change. If the car has more than 60K miles on it, I'd also have someone replace the distributor drivebelt.
Old Mar 28, 2007 | 11:06 PM
schwab's Avatar
schwab
Thanks, By the way I am a rennlist member but not updated as of yet. Will a bad o2 sensor cause a miss-fire?
Old Mar 29, 2007 | 02:35 AM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Have you tried reading the fault code with the accelerator pedal?
Old Mar 29, 2007 | 04:44 PM
schwab's Avatar
schwab
Thanks Jason,
I'll give it a shot tonight.
Old Mar 29, 2007 | 10:13 PM
schwab's Avatar
schwab
Worked like a charm - o2 sensor!
