Porsche 993 Technical Service Bullitens TSB's updated regularly
1- balast resistors_2000_61010.pdf
2- Battery_1997_62017.pdf
3- becker radio retrofit_1997_69037.pdf
4- Becker retrofit II_2001_69061.pdf
5- CD Changer_1996_690296.pdf
6- Chassis Noise_1996_640596.pdf
7- Distance spacers_1996_640296.pdf
8- Door Air leak_1997_67017.pdf
9- Exhaust bad smell_1996_620496.pdf
10- Exhaust tips_1995_620295.pdf
11- Fender liner_1996_650196.pdf
12- Fluid capacities_x_1994_600194.pdf
13- Front-rear lid paint_1994_650194.pdf
14- Headlight bracket_1999_69019.pdf
15- Hydraulic lifters_1997_610297.pdf
16- installing 18 iNCH wheels_1996_640496.pdf
16a- iWinter Tires Wheels 4440_1998_64028.pdf
16b- summer tire4440_1997_64047.pdf
16c- Summer tire 4440_2003_640703us.pdf
17- Litronic install_1997_69027.pdf
18- Lowering Chassis_1999_64019.pdf
19- Maintenance-warten95.pdf
20- New ABS sensors_1997_64097.pdf
21- painting Targa Wheels_1997_60017.pdf
22- PowerSteering OIL_1996_640696.pdf
23- Retrofitting R134a A-C_1995_680195.pdf
24- Retrofitting Tiptronic_x_1995_630195.pdf
25- Shift boot_1995_630295.pdf
26- Steering Column Noise_1996_640796.pdf
27- Tachometer_1998_69058.pdf
28- Vacuum lines_1996_620596.pdf
29- Pulley update 1997-06.pdf
30- self dimming mirror.pdf
31- readiness code 993-1997-07.pdf
32- 993 paint corrosion5106_1995_650195.pdf
33- 993 carrera chassis 4040_1994_640894.pdf
34- steering rack brace4440_1996_640496.pdf
35- Third brake light 6638_1996_660396.pdf
36- clutch pressure plate-3050_1996_6tu30696
37- engine wiring harness 9752_2002_6tu901a02
38- noise hydraulic brake booster pump 4761_1995_6tu40695
39- oxygen sensor 2469_1996_6tu20396
40- replace hardware when removing engine-1996_6tu10196
CABRIO
1- cabrio pins6110_1995_661395.pdf
2- cabrio top 6101_1995_660595.pdf
3- cabrio top clearance6128_1995_660495.pdf
4- cabrio top motor6107_1996_660896.pdf
5- repairing cabrio top6101_1995_660895.pdf
6- cabrio top tool6485_1997_660197.pdf
TARGA
1- targa roof6006_1997_66037.pdf
2- targa roof axle6040_2000_66010.pdf
3- Water entry areas 60_x_1996_660196.pdf
On Board Diagnosis and Error Codes
1- factory detailed engine specification.pdf
2- diagram vacuum lines .pdf
3- components location 993 .pdf
4- diagnostic trouble codes (text) .pdf
5- p1124 - p1126 .pdf
6- p1127 - p1129 .pdf
CABRIO
TARGA
The following 4 users liked this post by geolab:
Geolab,
Many THANKS !!
Many THANKS !!
Great job and thank you geolab!
I am especially interested in one of the TSB's #16 on your list.
I heard there might be another update to it again in 1998.
The info I have is TSB #4440-4 released 8-21-98
Can you confirm this or would you possibly have that TSB?
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
just added it under 16a, cheers mate
