Porsche 993 Technical Service Bullitens TSB's updated regularly
#63
Geolab, PM sent
#64
Originally Posted by glenn '88 944S
Geolab, PM sent
#67
Geolab,
THANKS Very Much !!!
Glenn
Glenn
#68
more added...
#71
section 36 - 40 added
#73
Thanks Geolab, that's excellent info. Two questions:-
1. The links you listed, can I save the links somewhere for future reference?
2. For the wiring at the rear of the HVAC on the self dipping mirror install. I am guessing the connections on the back of the HVAC will not be conveniently numbered to match the instructions and I will need a blueprint of the connections showing the relevant number. Am I correct? If I am where can I find such a diagram.
Thanks a bundle for the great response!
#74
Hi,
1- when you click on a link and a page opens, go to file->save as-> and save the file in a folder on your computer (better than saving the link)
If you insist on copying the link, point with your mouse arrow on the link, right-click and choose 'copy shortcut' and then paste the shortcut in a word file or pad file.
2- at the rear of the CCU (or HVAC) connections ARE very well numbered and each pin is individually numbered renderring the instructions very very clear. Just be sure what your VIN is, as described in the process.. good luck
