How tight must the distributor caps be?
I am at a standstill with my new dizzy install. I got the old one out and new one in and I cannot make the new cap screws thread. I get them almost all the way and then they just won't budge anymore. On the primary cap I retapped the screws and got them in, though with a lot of effort. On the secondary, I gave and reused the screws from the old cap. No dice. I really, really don't want to have to pull the dizzy back out and retap the screw holes and there's no room at all to do it while it's in the car. Now the cap is slightly loose. Is it ok to leave it like that? I am losing my mind and certainly my patience with this project. How can something so small stop this whole show? Please help!!!!!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Caps must be tight not only for the obvious reason, but to help keep moisture out. Take a screw all the way out of an old cap and compare both dizzy's.
As I remember, they have a metal sleeve and the screw bottoms out to a tight fit........? (thinking back)
They were a bear to get out (old screws) but my new ones went right in. Are you sure you didn't cross thread them?
Seared
Originally Posted by 993inNC
As I remember, they have a metal sleeve and the screw bottoms out to a tight fit. They were a bear to get out (old screws) but my new ones went right in.
Andreas
I must have cross-threaded them, but I find it hard to believe I did it to all four. Anyway, I took the dizzy out again (5 min.), threw in the vise and retapped the threads. All went together fine then. I put the secondary cap on while on the bench. No point in making it harder and I just made sure the rotor on the primary was at TDC when I put the dizzy back in. Check out the photos on my other thread in a few minutes.
