question about sports suspension
I want to use bilstein struts and bilstein shocks in the rear. If I use this combination, can I bring the car down to r.o.t.w. ride height without changing the springs? Would like to keep the car as origional as posible I would sacrifice ride height to keep the origional springs. Any sugestions would be appreciated.
So, to answer your question, no you cannot as springs set the height of the vehicle not shocks-unless of course the struts/shocks must be mounted in a way that change the stock geometry but this does not occur with the Bils.
You need Euro 030 springs to get the ride height you are looking for or another type spring like H and R if you want to go non OEM.
You can find used Euro M030 springs. At the time I was looking, I found 2 sets in two days LOL!!!
Jukelemon, the Bilsteins have an adjustable spring perch, so there's about an inch of lowering available independent of spring length.
