rear 19x10.5 with 58 offset, will it fit a widebody?
It probably will, but not without spacers.. ET40 is the normal WB offset (given a 10" rim) and ET65 is the rear offset for a NB (given a 10" rim). I am assuming you are talking rear fitment here
. Front should be somewhere between ET46 and 52 depending on rim width. So if you put on for example 17mm spacers in the rears, it should work.. Any pictures of the wheels in question?
That is a narrowbody offset that keeps the same inboard clearance and reduces the outboard fender clearance by 1/2" (compared to a factory twist 18x10" ET65). While not ideal this wheel will fit your widebody cab as it but will look a bit funny....if you want it to fill the wheelwells you will need to add a 1" spacer.
Can I ask why not? Not trying to be a smart -ss but just wondering what you are concened about. My (all) C2S's came with spacers standard on ther rear from the factory with 17" wheels.
Regards
Regards
Also, Porsche does not "approve" 19" wheels on the 993. Not quite sure what the reasons are, but they are careful to say what tire and wheel sizes they think are OK. I think you'd get a crummier ride without much upside (looks or performance) over 18".
Originally Posted by allill
Thanks Steve. I just wasn't sure if running a spacer was a good idea or not. Also, would I need a one inch spacer or a thinner one?
A 1/2" spacer would get you back to stock dimensions, approximately. This offset is 18mm less, add the .25" of the wheel width to the outer edge, and you end up about 12mm narrower than stock.
