Dead Battery =0(
Will the Porsche battery tender "charge" a practically dead battery? My car sleeps in the garage, but with the cold weather we have had lately and not driving it for a few weeks, the battery is practically dead (turn the key and barely get a door ajar chime and the gauge lights is non-existent). Can/should I charge the battery first with the Porsche battery charger (if even possible) and then if there is still not enough juice jump it with a battery pack?
I'm just thinking if I can help alleviate some of the strain to the battery by charging it first, it will cost least "wear" on the battery or will it not matter?
Any suggestions are greatly appreciated. Thanks!
Originally Posted by TRINITONY
happen to me a week ago..trickle charger overnight was fine...
Thanks for the lightening-quick reply!
Charging batteries is actually kind of a science. "Smart Charger" makers developed algorithms to try to prolong battery life by proper charging, like fluctuating the current and varying the level over time. Charging it with a trickle charger is certainly NOT the optimal method, but it'll probably work fine.
process which is supposed to increase battery life.
Most if not all tricklers are not made to charge a battery gone dead, not enough amps. need to re-charge it with a 12 amp charger and then keep it on the trickler. I understand that the cigarette lighter chargers are not as good as the outlet chargers. I recently tried to start my 964 to check if the battery was good on the trickler and it would not turn over although all accessory equipment, radio, lights would work. The battery needed to be put on an overnight 12 amp charger. I had the trickler replaced with same brand, it was 15 months old. I keep my trickler on at all times even in summer as I only pleasure drive the car, so I don't know if these tricklers have short life cycles.
