More help needed - burning plastic smell & smoke
I am going have the compressor replaced by mechanic as soon as i can sched an appointment. My question is can i still drive the car as long as a/c is turned off? I already removed the clutch (came right off). Should I also remove the a/c belt and drive it that way? -Thx Joe
Hi, judging by the original post date I'm nearly two decades late to the party!. However if anyone is still out there, I have exactly the same issue on a 95 993 c4s. Seems to run fine with air-con off but all manner of smoke and whining emanates from the back when I have fan and air con on (even without my in-laws in the car).
Just wondering if you found a resolution, was it a new compressor or bearings or both?
Cheers
Cheers
Have you tried checking the engine compartment when the AC is on to determine source? Sounds like a stuck or damaged compressor? Belt problem?
