Why Would Battery Be dead?
Put in new optima red top in my 993 in December. started right up over a two week period. put on a porsche lighter charger .didn't try it for almost two months now. dead again.. any ideas how this can happen . have had an optima in a 356 for years without problems..
Could be a bad battery, it happens, not all batteries, even from the same manufacturer are the same, that is why they have dated warranties and there are schedules to prorate their value. I would take it back to where you purchased and exchange it.
On the other hand, you could have a electrical problem, but I would look at the battery first.
The security (alarm) unit in the 993 seems to be quite a power hungry beast. I have the same issues, and I gather all of us have. I seem to remember there's a procedure for locking the car without the alarm system activating, involving using the interior lock button from the passengers side, but my recollections are a bit sketchy at best. Maybe you could try this.
My experiences with Optima's aren't err...optimal.
Peter R.
Peter R.
If you are referring to a charger that you plug into the cigarette lighter, I don't think they work for our cars. My understanding is that the cigarette lighter needs to be working when you try to charge it, and ours don't have power when we take the keys out. If you left your ignition on, it may work, but I wouldn't want to leave my car charging in this state!
Originally Posted by Peter R.
My 993 does have power to the lighter when switched off !
Peter R.
Peter R.
A very basic way to see where the draw MIGHT be coming from is take a blown fuse and insert it one at a time in all the fuse positions and use a DVM set to mA's and track which fuse locations have a draw and how much that draw is. I don't think this will work if the draw is through a relay (depending on the circuit).
You need a blown fuse because you must test amp draw in series and that can be done by putting the test probe tips on the top exposed pins of the blown fuse.
(My DVM probe tips won't fit down in the fuse slots to make a connection which is why I use a blown fuse)
I have the same problem in my current (1995) and former (1996) 993. The optima goes dead after about 3 weeks of non-use. Pretty darned annoying. I have an aftermarket alarm on my 1995 instead of the factory immobilizer/ keyless entry system on later 993's.
- Switch the igntion on and off, remove the key and close the door.
- Install multimeter between the battery minus pole and vehicle body. Then disconnect the vehicle ground strap at the body mounting point. This will prevent interrupting the circuit and allowing the relay to collapse.
- start pulling relays individually.
Originally Posted by JasonAndreas
Porsche even warns in a TSB (Diagnosing Discharged Battery, March 29, 1994) not to directly probe the fuse contacts so you don't spread them.
It figures, the one time I was doing something right it was by accident!
I also had big problems with my battery. But I found a simmple solution ;-) which switches off the alarm but takes care about the battery. And nobody will be able to start the car either. See link.
http://www.automotion.com/productpag...ery+Disconnect
