993 Forum 1995-1998
Up and down revs on cold start
Old Feb 6, 2007 | 10:32 PM
carreranow's Avatar
carreranow
Default Up and down revs on cold start
anyone have any experence with this....'95 993 w/ low miles.
When car is started and engine is cold, revs will fluctuate up and down for maybe 10 seconds or so then go back to normal. Want to nip it in the bud so it doesn't lead to a bigger problem.
Thanks!
Old Feb 6, 2007 | 10:37 PM
briefescape's Avatar
briefescape
My 95 993 with high miles does exactly the same . I am not worried about it though it is the beast just waking up
Old Feb 6, 2007 | 10:40 PM
faster's Avatar
faster
I had the same problem in a 3.0 car and replaced the cold start valve, but have not experienced it with my 993. have you tried a search of the forum yet.
My Grand National does it pretty regularly which they are known for, but that is the IAC.
Old Feb 6, 2007 | 10:49 PM
ARM993's Avatar
ARM993
My 95 with 56K miles does it too. The colder the day the longer it does it. Particularly this week after sitting in the lot during the day with a wind chill of -15. But usually no more than 5-10 seconds. I'm not particularly worried about it as the car is running great.
Old Feb 6, 2007 | 10:51 PM
FLYT993's Avatar
FLYT993
Same here. 95 993 with 64k and she does the same thing....
Old Feb 6, 2007 | 10:52 PM
cowtown's Avatar
cowtown
ISV. Search on "idle stabilizer valve."
Old Feb 6, 2007 | 10:59 PM
Mark in Baltimore's Avatar
Mark in Baltimore
Yup, clean out your ISV valve.
Old Feb 7, 2007 | 12:11 AM
brucec59's Avatar
brucec59
Mine does it, too. It used to do it more than it does now, tho. Maybe it's just happier being driven. I have cleaned the ISV, but that didn't seem to change anything at the time.
Old Feb 7, 2007 | 12:22 AM
ARM993's Avatar
ARM993
Looks like a good project for this weekend. No sense in leaving it alone now that I know how easy it is to fix. Thanks guys. Here is a good thread on the ISV. A few posts down there are a couple helpful DIY links to p-car.com.
https://rennlist.com/forums/showthre...abalizer+valve
Old Feb 7, 2007 | 12:59 AM
jnnking's Avatar
jnnking
Interesting, mine does it too (63K). I guess I can add this to my spring project list. Thanks guys ;-)
Old Feb 7, 2007 | 01:09 AM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Its just a sluggish ISV valve -- clean her out, and all will be good!!!
Old Feb 7, 2007 | 01:08 PM
tj90's Avatar
tj90
See what I mean - hanging out on the board you find out about problems you did not know you had 5 min ago. My 95 with 116k miles does it in the morning...
Old Feb 7, 2007 | 01:11 PM
clipstone's Avatar
clipstone
Must admit I thought it was just "one of those things" about the car - does it for a coule of seconds when cold - will have a look at the ISV now!
Old Feb 7, 2007 | 06:00 PM
Monty's Avatar
Monty
It doesn't improve with miles - mine's done 160k and fluctuates for 5/6 seconds when temp is less than 5deg C. Don't worry about it.
Old Feb 7, 2007 | 06:11 PM
Red rooster's Avatar
Red rooster
Lets see if cleaning the ISV does anything.
The DME has a fuel enrichment map that is head temperature driven . A combination of top tolerance fuel pressure and lowest tolerance head temperature sensor will lead to a slightly overrich mixture and then slight hunting. All motors hunt with too much fuel.
Soon as the head warms up a little, its all over .
I seem to remember that Porsche say to fire up and drive away . First set of lights everything will be fine .
Geoff
