993 Forum 1995-1998
Spring removal
Old Feb 5, 2007 | 10:03 PM
993polarsilver's Avatar
993polarsilver
Default Spring removal
I am finally upgrading my shocks to Bilstein HD's. A friend of mine gave me his old stock shocks that are fitted with H&R springs. I need to harvest the H&R springs from his shocks in order to get the Bilstein HD / H&R combo.
My question is whether the springs that are mounted on the old shocks are under load. I recall someone in a post awhile back saying the the springs were not compressed if the shock assembly is off the car. I would hate to lose my head while trying to upgrade my suspension. TIA for any advice.
Old Feb 5, 2007 | 10:09 PM
InTheAir's Avatar
InTheAir
I agree that there probably isn't much load on them; however, just don't point them at your head for the last couple turns of the retaining nut. It shouldn't be a problem.
Old Feb 5, 2007 | 10:14 PM
Jack of Hearts's Avatar
Jack of Hearts
Very little load when off the car. For safety, have someone stand on the strut while you remove the top nut using a long extension. Wear gloves.
(But I did it myself with an air wrench and had no issues.)
Old Feb 5, 2007 | 10:15 PM
993polarsilver
Thanks Jeff, I looked through your suspension DIY for inspiration. What a great write up.
Old Feb 5, 2007 | 10:53 PM
InTheAir's Avatar
InTheAir
Are you going to install them yourself???
