18" Turbo Twist Wheels on 993 C4?
I have an opportunity to buy a set of 4 x 996 18" Turbo Twist wheels. The wheels come with tyres having 50% tread depth. I am hoping to use these for the occasional track day.
Will these fit a bog standard 993 C4?
I don't want to have to do anything except unbolt my factory 17" and bolt on the 18" wheels.
Thanks in advance.
Mark
Thanks in advance.
Mark
Mark,
I've got the same 18" OEM Twist wheels for AX / DE's 225/ 40's front and 265/ 35's rear, the one's you see in my avatar. The offsets on the back of the rim should be ET 50 front / ET 65 rear. I've got a set of 285 Dunlop Sport Race that fit with out rubbing on our narrow bodys if you want go wider. Rick
