C4 ABS Question
Does the NB C4 have the same ABS setup as the C4S and TT cars. Is the ABS pump a 4-channel ABS system. Also, is the entire brake system on the C4 different then a NB C2.
Thanks,
Thanks,
From a similar question I asked some time ago.......
The ABS/ABD (options M224 & M339) hydraulic unit part number is #993-355-955-50. However, you may also need to replace the ABS control unit depending on the production date of your 993. The Porsche part numbers have stayed the same but the units were revised so if the serial number ranges don't match you'll lose ABS functionality. If you are replacing the hydraulic pump on a MY94 or MY95 check the ABS control unit serial number for a 4-digit production date (in bold below)
ABS-Control Unit (993-618-125-00)
DI015193XXXX
ABS/ABD-Control Unit (993-618-126-00)
DK094593XXXX
If you have a 3-digit production date (in bold below) you have the old style control unit and will need to also replace that.
ABS-Control Unit
DI013720XXXX
DK093710XXXX
if you are replacing with a newer style hydraulic unit. The newer style units have a serial number greater than (in bold below)
ABS Hydraulic Unit (993-355-955-00)
462/502372
ABS/ABD-Hydraulic Unit (993-355-955-50)
463/505058
DI015193XXXX
DK094593XXXX
ABS-Control Unit
DI013720XXXX
DK093710XXXX
462/502372
463/505058
The NB C4 (and C4S for that matter) does in fact have the same braking system as the Turbo, which is different from the C2. However, the difference lies in the brake booster setup--the C2 has a vacuum brake booster and the C4 & Turbo have the hydraulic brake booster.
The C4 & Turbo come with ABS and ABD (automatic brake differential) and, because of this, have two brake power controllers versus the single brake power controller in the C2.
See the "Mighty One" comes through. Jeff to clarify. The C4 does have the same brake system as the Turbo, but the calipers are C2 type. Right? Just wondering.
Mike
Mike
Weathergirl
Originally Posted by InTheAir
That's correct--the NB C4 has the same calipers as the NB C2.
DI015193XXXX
DK094593XXXX
ABS-Control Unit
DI013720XXXX
DK093710XXXX
462/502372
463/505058
DI015193XXXX
DK094593XXXX
ABS-Control Unit
DI013720XXXX
DK093710XXXX
462/502372
463/505058
I have been thinking about a NB 993 and doing an RS Clone track car, and others have pointed out that the C4 is a good starting point because the ABS is the same as the RS.
I know it doesn't make sense to make a C4S 2wd, but a C4 might be not as bad. Plus I don't want to get into the arguement about RWD vs. AWD.
The other issue is that the C4 doesn't have the big brakes to back it up, and if you do big brakes fall into the preped category.
Thanks everyone for the quick response. It is kinda strange that all the C4 responses are Cabs.
