993 Forum 1995-1998
brakes
Old Dec 30, 2006 | 08:36 PM
KBell's Avatar
KBell
Default brakes
Good evening Rennlister
I have a '95 993 with 105000 miles.
I am going to paint my brake calipers and replace the cracked brake lines.
My question is "Do I need to do a brake caliper rebuild while I'm in there?"
The brakes wear evenly and there are no cracks in the dust shield (boot).
I do two driver's ed. a year.
Old Dec 30, 2006 | 10:12 PM
gordo993's Avatar
gordo993
Hi Kevin,
I didn't rebuild my calipers, however I have 1/2 the milage you do. I would guess that unless you have a frozen caliper, a rebuild wouldn't be necessary. Are you disassembling the calipers to paint? Are you using a brush-on kit? I am planning on helping rkb with the same project over the winter - maybe we can make it a party!!
Happy New Year to you and yours!!
Old Dec 30, 2006 | 10:40 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
The dust boots could last another 40k miles but if you already have everything apart and you're going to paint the caliper its easier to get it out of the way now.
With a dental pick the seals and boots are trivial to replace but they are expensive at $50USD per caliper. And just as important but way more of a PITA are the spring plates at $26USD per caliper. It is easier to paint with them removed but if you can install new brake pads without having to file down the edges to get them to fit you should be okay with your original spring plates.
You're looking at seals that are 100k+ miles and (possibly more important) 10+ years old so if you can replace them now instead of later when they've had a chance to allow dust/dirt/whatever to ruin the piston bore, you'll save yourself a few dollars not having to buy a new caliper (not that I've heard of many/any people requiring new calipers).
DocTock993's Avatar
DocTock993
You guys (kbell & gordo993) are about equal distances from me - we could figure something out.
Old Dec 30, 2006 | 11:35 PM
KBell's Avatar
KBell
Thank you for your replys.
John, I an going to use the G-2 paint from tire-rack.
Your brakes have inspired me.
I don't know when I am going to do this.
Just trying to get everything together.
I'll let you know
Jason, thank you for your advice.
I will replace the seals whenever I do the brakes.
Old Dec 30, 2006 | 11:43 PM
Scott 1996 993c2's Avatar
Scott 1996 993c2
What color will the calipers be?
Scott
Old Dec 31, 2006 | 12:31 AM
gordo993's Avatar
gordo993
FWIW - I didn't disassemble mine (didn't even remove the rears) to paint. Just clean clean clean clean clean clean. When you're done with the cleaning, clean some more. The better your cleaning job, the better the end result.
Old Dec 31, 2006 | 12:10 PM
KBell's Avatar
KBell
Thanks John.
I will definately clean them.
Scott... I plan on keeping them black.
Happy New Years
