Front Hood Shocks DIY (1/2 way)
#31
I just went through most of the same trials and tribulations when replacing both sets of Hood and engine struts.
I thought I hit the jackpot when I ordered them and they did not break my wallet. The pelican parts catalog also reccomended buying a couple of the metal clips. I knew better
I had trouble on the lower front mounts as they would not come off. Before that I popped of the upper clip and it of course disapeared into the black hole below. Next I realized my hand did not get down there.
I know, screwdriver with a piece of chewing gum
It actually worked.
(I subsequently bought a telescopic magnet with light on the end from Sears
That works a lot better when I had to do it all over.
I felt very accomplished when my 11 year old nephew and his skinny arms and I finished the front ones
The rears proved to be even more fun as I had to remove the intercooler unit as well as a number of air filter and other parts just to reach the back. It took at least 2 hours with the small arms and fingers of my nephew and a lot of
but I got it done. I did however lose the nut to the intercooler in the bottom of the engine compartment (R.I.P). The new nut was $ 8.00 and the old one will be found 5 years from now by a Porsche mechanic.
DIY projects - Aren't they fun
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
![bowdown](https://rennlist.com/forums/graemlins/bowdown.gif)
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
![bigbye](https://rennlist.com/forums/graemlins/xyxwave.gif)
#38
Originally Posted by 24FPS
i'm guessing the life-span on these is about 10 years, mine are startin' to go
#39
Originally Posted by wayne325
Maybe a bit late for some of you guys and gals but there is an RS piece that is just a stick
that you put into place in a receiver cup and it holds up the front lid. I think this one lasts
forever and it will save a tiny bit of weight. You can order from Carnewal, it's 22 euros.
Kind of expensice for a stick but it's supposed to be a genyoooooine part.
When I did the rear shocks, I put a towel underneath to catch anything that fell.
#40
"i'm guessing the life-span on these is about 10 years, mine are startin' to go...
10? After a couple of new sets went south, each after 6 months, I grew tired and developed this solution. Unlike the RS version, there's no drilling and it fits anything between a 912 and a 993 (haven't verified on a 996 yet).
Sherwood
(is this blatent advertising?)
Sherwood
#43
I just did mine in 25 mins. (driver side took almost 20 mins, everything went wrong-drop the clip, hard push to get pivot pin out, took a while to figured out that hood can actually go up more in order to position that shock in between!)
Overall, it was very satisfying experience. If I can do it, anybody can!!!
#44
Did my front hood shocks last night. Prepared for the worst but, after a 10 minute look-see, it took 5 minutes for the driver's side and 2 minutes for the passenger side. Simple pop out, pop in install. Did the rear deck lid shocks a few months ago. Mostly done by braile, but no problem getting both sides done in < 1/2 hour. Don't know what all the fuss is about. Must not have done something right.....
-Jim
-Jim
#45
So, tell us, after you were done, did you stand back and admire how the hood just stayed up "all by itself"?
