Check belt light: 10 bad seconds in my Red Thing
Thanks to you both. Now I get the idea. Kind of a fancier allen key! Will start searching -Cheers - TT
Originally Posted by STLPCA
Here's the Porsche part:
Originally Posted by Thaddeus
Thanks for the good info. Belts are on order.
NOW: where can I order a day somewhat above freezing when I can do this work?
I ordered them this morning from the local stealer. This is turning into an expensive little belt change... Oy.
Not sure how to tell. I guess the washer would give it a way?
Deer Slayer
Well, the stealer didn't gt my new pulley in on time , so I went ahead and replaced the belts this morning. I can replace the pulley when it comes in, the hardest part about this job is dinking with the A/C compressor anyway and I don't need to monkey with it if I'm not taking the belts off.
It was 40 degrees outside and sunny, and the job took about 2 hours. I got the 10mm triple square at Napa on Friday, it worked fine. Nice to have new belts on there.
Deer Slayer
The new pulleys are installed. I did need them. I had to add a spacer-washer. So anybody else who plans to do this: be sure to have extra washers on hand.
Amazing how much satisfaction I derive from correcting something that is so small in the larger scheme of things.
Thaddeus your English is impeccable
Today on the drive home my check belt light illumined for about 5 seconds....Thaddeus
Except Thaddeus.
JoH
Deer Slayer
Originally Posted by Jack of Hearts
I read this whole thread just waiting for Thaddeus to say something like "illumined" again. Nobody speaks correctly on the Internet anymore.
Except Thaddeus.
JoH
Except Thaddeus.
JoH
Deer Slayer
Just replaced my belt sensor. It took about 10 minutes. The old one's bearing was so grunchy I'm surprised it hadn't melted. The engine is quieter now too!
