Just got back my 95' 993 from top end re-build
Originally Posted by 993c2cab
a used cat bypass pipe. thanks
Originally Posted by pchansen1
So, I still gotta ask as I too have a 95 993 with 80K on the clock...how much should I budget for exactly what you had done?
Thanks,
Paul
Thanks,
Paul
Originally Posted by jdistefa
Did you upgrade the valve springs while you were in there? I.e. to reduce hi RPM float?
Originally Posted by fast_freddy
I just got my 993 back from a top end rebuild and a variety of other mods and I have to say WOW, what a difference. The following things were done to it:
- Complete "valve job", Replaced Valve Guides, piston rings, case o-rings
- Replaced clutch and flywheel with RS spec
- Replaced engine mounts with RS spec
- Replaced plugs, plug wires, caps, rotors, belts (including dist belts), gaskets
- Installed Cat-Bypass pipes
- Align/corner Balance
Originally Posted by Monique
Of you observe the red line, you should never float your valves. Over the red line, the bets are off. Increase rpm = new conrods. $$ ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I asked the question based on 3 factors:
1. The sometimes mentioned, but to my knowledge, never proven concern about valve spring fatigue over time.
2. Racing/DE applications.
3. New chip or remapping to change the rev limiter setting.
Originally Posted by BrokenE
Fast Freddy, your car looks great, I really like the RUF wheels. Just wondering, is it normal to do replace piston rings on a top end rebuild? ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Steve Weiner, are you there?
![](https://rennlist.com/forums/images/ranks/veteran_army.png)
Good question... I figured that "might as well while you're in there", the cost was nominal. However, whether its necessary or not I don't have an answer for you.
JP,
Regarding point #1... metallurgy never forgets. This is why turbine engines are operated at the lowest possible setting for take off given present runway and environmental conditions. Valve springs do lose some of their "spring" ...
Can a real "nennenneer" pipe in...??
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
About $8k.
Jim
Hello Matt,
Can a real "nennenneer" pipe in...??![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Originally Posted by jaholmes
Was there ever an option to go to a 3.8 build. Just wondering if you had a quote for this. I hear that the pistions / parts for a 3.8 build is around $7k. So I am betting it would have doubled the price. It might even be more if you throw in RS Cams and other goodies.
Jim
Jim
