Has anyone removed the sound foam while recarpeting?
So I have my carpet completely stripped out, and I'm just looking at the thick foam underlay thinking "gee I bet I could save some weight here." But I assume that installing carpet over the bare metal either wouldn't work or would just look bad. Has anyone ditched the foam and then recarpeted?
BTW, my car isn't a complete track car, so I want to maintain a good appearance.
EDIT: just to be clear, I'm mainly referring to the entire back area and front center console. Not just the floors. Every single piece of carpet is out of my car, with just sound foam remaining.
Yes. Follow the link in my signature for some details. The floor under the drivers and pax side is not level and you will have to create a level surface for the carpet. Otherwise it's about 30# of unnecessary weight.
Originally Posted by Don Plumley
Yes. Follow the link in my signature for ...
Hi Other Eric
My track car has the floor carpeting removed; I can snap and post some pics if you like.
Carpet was removed when converted into a track car, althought the RS (?) lightweight carpet replaced the factory orginal on the side panels and rear floor.
I too was worried about abuse of the wiring harness; everytime I hopped into the drivers seat (not easy with a helmet and full cage) my right foot landed on the harness - which is a bundle of really important tiny wires.
So, I snaked the wires into a piece of clear plastic tubing and used some tape to bind it shut.
Let me know if I should shoot the pictures.
Originally Posted by pcar964
Can't buy a replacement? It must be available somewhere!
Katrina- I got a replacement carpet set from world upholstery (www.worlduph.com). I haven't installed it yet, but it looks to be excellent quality. We'll see at installation time.
Originally Posted by RickBetterley
Replacement foam pieces -I wonder if these could be mocked up, since they are not visible.
Rick- can I take you up on that offer for pics? I'm interested in the rear area and center console area. I'm still trying to figure out what Don did to his center console area- looks like he installed *something* over the metal center tunnel before carpeting. Don?
Hi Eric
Glad to do the pictures, although the center console is carpeted; it is only the floors that are uncarpeted.
Would the this still help you? Glad to do the pics if they do. Probably can get to them tonight.
It's PITA to remove it (I lost the skin on my fingers) but definitely worth it!
You'll end up with little gaps (i.e. under center console) but overall it looks good without the carpet. not only weight, but also the sound is improved, especially if you also remove the engine compartment sound deadening, you'll hear more lovely mechanical noises!
Originally Posted by TheOtherEric
The foam parts that go under the carpet are pretty thick with a rubbery/plastic surface and are huge molded pieces. *If* you could buy replacements, they would surely cost a fortune. I'd be surprised if they're available since practically nobody would ever need to buy them.
Replcaement foam pieces under the front mats is 70US each side.
I threw them out and thought I coudl live with teh uneveness of the floor underneath.... I could not.
Pros? Lighter = fast
Cons? get's noisy. You hear ever rock that hits the bottom of your car and a little more rattling.
Originally Posted by Greg Fishman
I just bought a set for my 993 from Sunset. Aprox $200 for the set.
