Modifying Stock Sway Bars
Drill forward of the factory hole, same size, as far forward as you can, before the bar goes tubular. When you mount in this position, the bar will be "shorter" which equals stiffer. The math behind exactly how much stiffer is way over my head. And in the final analysis, you probably don't need the extra hole in the first place.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
You'll also have to grind or 'extend' the flat section where the drop link fastens to the bar to allow a parallel surface for proper fastening. Easily done with a drum sander in a Dremel tool.
