PSS9 with RS camberplates.
Last weekend I was on my way to install PSS9 on a 993 with RS Camberplates (uniball) in the front.
I had to give it up, the camberplate stackup was totaly 54 mm while the top end of the PSS9 was only 42 mm, resulting in that the end with the threads did not come trough and the nut could not be put on.
Have anyone else experienced the same?
The front camber plates of the 993RS will not work with the PSS-9 for the reason you mention :The stud is not long enough.
The rears are OK to use but you will need aftermarket ones for the front.
