Litronic Questions
should I just go aftermarket and keep the originals?
Enjoy,
Originally Posted by bobhig
does anyone know what the option code was for LITRONICS? My car has lots of options. Some I've figured out (from Adrian Streather's book) but a couple I havn't.
Bob
Bob
read two quotes up, M601
Litronics were not standard on the Turbo or any other model
Originally Posted by Joe S.
...If you don't have them, I'd say get the real thing.
paranoid? dunno...
just my 2¢.
Originally Posted by urban_alchemist
Any more details of this? I went to the website and couldn't find anything...
http://www.jzmachtech.com/shells/tun...r=1996&id=9038
Also here (not OEM, but recommended by some Pistonheaders):
http://www.aceparts.com/
So is there any reason to fit the Litronics, or should I just go aftermarket and keep the originals? From someone who has them...
Originally Posted by mborkow
are you sure about that? i thought that they were standard on the TT (and i got that from one of the most well respected sources here on RL).
You can get factory Litronics for quite a bit cheaper than what geolab has indicated. Try www.departstop.com and ask for Dayton.
Dave
Dave
Litronics were standard on the European LHD Turbo's that I have seen, but not on the UK RHD models for some reason.
Doing a search,I ended-up on this,
Instead of opening a new trd,It's better to finish this(for the posterity)
and I'm still not sure if the difference is about the possibility to control the levelling of the headlight.
Any help,because it seems that some litronic had the level control on the lh side of the steering wheel,other ,like mine hadn't….
