How do i know if my nokia amp is working?
I plan to do a stereo upgrade, are the works, but in the mean time how do i know if the factory amp is working, and is the fuse on the amp or with the other fuses ? so I can see if it is out. the car is 8 years old.
1 Post
If you are doing an upgrade dump the amp. Don't know about the fuse, but if you have sound it is working. Are you sure you even have the nokia? It's under the passenger seat and the wires to the speakers go there as well. I think those stock speakers are like 12 ohm or something crazy, and I also think the amp is crazy. I added good speakers to my nokia and it sounds a lot worse than adding good speakers to just the becker for some reason. If you are really doing an upgrade, then you will want to increase the size of the speaker wire - if you are doing that then you prolly don't want to run them back to the nokia. I think a serious upgrade would involve an amp in the boot and fresh wire and speakers. .02 in 10$ wrapping
