993 Audio system woes
Originally Posted by brucec59
Using a battery on a speaker is one thing, but on a line level input it might result in a really big thump.
Unless the amp is on, a battery at the amp's input will not produce any sound at the output (speaker). If the amp is on, the input sensitivity might be 1v or less, which means connecting a 1.5V battery will produce a pop/scratch/etc at the full output level of the amp!
Seeing 1.5 V at the amp input is about equivalent to the head units max. preamp output, a mighty bang may ensue.
If you don't mind I'll use a wave generator ;P
Peter R.
Peter R.
Peter R.
Peter R.
I thought I made this clear but obviously not...
Well, it turned out the 4 speaker wires are individually screened, so I decided to just solder cinch plugs on them. They fit the standard pre-outs on just about any head unit.
All went well, but unfortunately I've now found that the speakers in the left door are permanently out to lunch.
I'll test the whole thing to see if maybe it's an easy fix, but I've had quite enough of the silly wires and built in amp now, and I think I'll just rip the whole thing out and put in some half decent gear.
Peter R.
Peter R.
