How to replace headlight switch
How do you replace the headlight switch? Can it be accessed by the panel with the two screws on the side of the dash? This portion of the dash with the two screws is flush with the door panel when the door is closed. If this is the right method, I guess you still have to work around the ac/heater dash vent that is going to be in the way....
I've found nothing on p-car.com nor in a Rennlist forum search.
Thanks in advance for any ideas.
chuck
chuck
