Anyone swapped sunvisors to fit a radar detector?
Hi Jon - I'm resurrecting your old post as I am looking to do a more rigid V1 mount like you've done. Drilling into the headliner makes me a bit nervous...I felt around the location you described and it seems the metal bar you described is maybe 3/8"-1/2" wide at most. Did you use a dremel or a punch to make the initial hole?
Also, do you recall what length sheetmetal screws did you use? Has your mount held up the past two years?
Thanks!
David
Thanks!
David
One thing to be careful about is the screw head shape. I got lucky and the screw heads are just right to provide friction against the V1's top and hold it in place.
I just used the suction cups that come with the unit and mount it just above the rearview mirror so there's about 2/8ths of an inch between the lower part of the dector and the top of the rearview mirror. I then ran the electrical wiring just under the window seal all the way around and down. At the moment the wiring is tucked under the dash but I plan to hotwire it to either the cigarette lighter or to the interior light power.
Just drilled it freehand with a collar on the bit so it wouldn't punch through too far. Then I enlarged the hole a bit and used fairly fat sheet metal screws. Don't remember the exact size, but once I got them started in the hole, I nipped off the points. The screw tips are probably no more than two threads in, but it's held up fine.
This is my current set up, but the suction cups tend to lose their grip after a few days. More importantly, the idea of a 3/4lb. metal box flying around the cabin at eye level in the event of an accident doesn't appeal to me
Boost Junkie
part of the issue is that those little black dots (WTF are those there for) do not present a smooth surface for the suction cups. Just put a piece of heavy clear packing tape over the area where you want to stick the cups to make the surface smooth and Bob's yer uncle
