HELP: Inner CV boot replacement kit
Hi,
My outer CV boots are torn, so I'll be replacing them. However, my inner boot is torn as well and last I heard there was a potential kit being developed by someone. Is there any such kit yet??? Or do i still have to replace the axle?
Thanks in advance for the help.
Boris
Boris
For a C2, if you are talking about this kit: 928-332-293-02-M60; it works for either inner or outer.
The p/n is for the boot. The clamps and grease are similar.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Boots are less than $6 from Pelican. Sometimes you can reuse the folded tab straps, if you are careful. Any name brand CV joint grease will work just fine, which can be found at any parts store. Good luck!!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Forgot to mention that sometimes the inner joint is tough to pull off (once the circlip is removed). A three jaw puller and a soft hammer will help if this is the case. Some just slide off, others are a bear.
Here are the parts and prices from Pelican:
Boot 928-332-293-02-M60 $5.25
73mm boot clamp 911-332-257-00-M100 $5.00
34mm boot clamp 928-332-257-01-M100 $6.50
Swepco CV Grease SWE-101 $9.95
Technical Guru
Yeah, I know this is an old thread. I just changed inner and outer boots on one side. Took three hours. Needed a 3 jaw puller to get the inner joint off the shaft. I did not take the axles out of the car. The pelican thread is pretty good at letting you know what to expect.
