Bosch hammer and other programming questions
If that is teh case, I should try and measure the voltage on pin 27, I assume. From there... jump pin 27 to +12 in that harness?
That still doesn't quite explain how to make this 00 box work, and whether it's supposed to work in place of 01 box at all.
My assumption has been that it's just a function of programming. Am I incorrect on that?
Technical Guru
Originally Posted by nile13
I do not have immobilizer in my car.
when the alarm box is removed from my car, the car cranks but does not start. How would that be explained?
The alarm functionality is a little criptic
DTC Memory (or Fault codes)
Drive-Link
Input Signals
but if you scroll to the right additional (hidden) menus will pop up
Country Codes
Result Memory
System Check
Remote Control
Vehicle Type
and under "Vehicle Type" you want to select, "911 Carrera (993)"
and under "Remote Control" you want it set to "Off"
and under "Country Codes" select "3" USA.
Technical Guru
The alarm box I have is a 01 part number. The second box I'm trying is a 00 part number. The no-start condition exists when I take my 01 box out. It is the same condition, whether the 00 box is connected or not.
"If the alarm is activated or (i think) if the alarm control unit is removed from the car then Term 15 (switched power) going to the DME control unit is interrupted and so fuel and ignition is shut off."
Right! Term 15 to alarm unit to pin 27 (run) of DME, if NO alarm condition.
Originally Posted by JasonAndreas
The reason you might not be finding the extra menus for the vehicle type and remote control (immobilizer) is that they don't exist on the software version 0 alarm units. What is the entire part number on your alarm control units?
My DME is 163, but I don't recall the full number. Jerry was mentioning that the hammer can't see the DME, but did not elaborate.
PS. BTW, how far are you out West? I'll be in Amherst on Saturday...
The concern is not to fry the innards of the alarm box if the pin 27 is tied directly to ground and not just floating. And it would be a bit too ghetto of a solution...
No alarm condition, I assume, is not the setting, but rather the fact that the doors are open properly and alarm is not blaring?
Jason, the Hammer seemed to have asked for the country code, but not the car type or remotes... It also asked for Anti-drive on-off and something like output (?) on/off.
Technical Guru
the control units are 928 618 260 00 and 01, I believe.
So pin 15 is directly connected to pin 27? And if I connect either pin to +12 it should work?
The 928-618-260-00 was used from MY91-94 in the 964. In addition to possibly not working with your DME control unit your interior lighting is not going to operate the same. But I can't locate any documentation that says yes or no that it will work. In theory it should but... Do you have Adrian's 993 book? There is always the chance that this particular issue is already covered.
Any ideas what's wrong with your original 01 unit?
I don't have Adrian's book, no. Somewhere I have a factory 993 wiring diagram but I've been leaving out of suitcases between here and Europe for the last year, so it's impossible to find anything.
The original 01 unit got, shall we say, wet. The central locking is completely dead. the red lights on the doors stay on.
The guy who sold me the 00 box assured me that it came from a 993. I'll press him again, but I'm afraid it's a lost cause.
Was the DME control unit responding with the working 01 alarm control unit plugged in? The same thing that keeps the engine from starting will prevent the 993 DME control unit from responding to diagnostic requests.
So... is it a dead 00 box, possibly? Or is it simply not compatible?
About 45 minutes from Amherst.
928-618-260-00 contains an old version of software which only allows the country code selection as an option, it doesn't support remote functionality or multiple vehicle types.
Term 15 is Porsche's generic name for switched +12V and is located on pin #6 (small connector) and pin #18 (large connector) at the alarm control unit. I only saw Loren's message after I posted and probably should have deleted what I wrote to reduce any confusion.
Would you have an extra 01 box floating around that you'd look to sell?
