Question about Secondary Air Injection on 993s
#31
#32
Originally Posted by Droops83
The SAI flush is a band-aid, the ports will eventually clog again. It may take, 20, 30, or 50k miles but they will clog again.
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
If oil consumption is O.K, then just expect to do the flush every 20-50K as scheduled maintenance. Not too bad, if you look at it in those terms.
#33
Technical Guru
Originally Posted by jimbo3
but the OBD1 doesn't have the sensors for SAI as the 96 and later models.
Originally Posted by 98993c2s
This problem is not only specific to 993s:
#34
"The difference is that the MY95 will only throw a code if the auxiliary air pump has a problem. MY96+ will also check the O2 sensors for a voltage drop when the pump operates and throw a code if that doesn't happen."
Monitoring the O2 sensor/sensors is really the proper way to fully check the overall SAI system,
i.e. not just checking that the punp operates. and that's why it's in the OBDII spec (>= '96 993)
versus ODBI ('95 993).
Check here ( www.systemsc.com/pictures.htm ) for info on 993 SAI problems.
#35
Technical Guru
i.e. not just checking that the punp operates. and that's why it's in the OBDII spec (>= '96 993) versus ODBI ('95 993).
#36
So, speaking of a proper CEL (Check engine light) diagnosis, there is even more to think about now that you know about the oxygen sensor voltage drop when activating the Smog pump. You also have to know about the characteristics of the oxygen sensor voltages and what they mean when you do this. They have different personalities at different times and eventually, to confirm our diagnosis, we have to access the suspect valve guides by removing the valve cover and rocker arm including valve spring to see what the guide wear actually is. I disagree that the CEL is the only problem. With worn out valve guides you are dumping tons of oil into your exhaust system and contaminating the oxygen sensors and catalytic converters. Your engine would not know how to run properly without the correct oxygen sensor signals. There is a lot more to the story than meets the eye. These engines are very good about not smoking and not fouling the spark plugs while having severely worn valve guides so the customer is misled into thinking that all is well.
