seat jammed!!
A couple years ago, I damaged the square end one of my drive cables. I coated the drive end with epoxy, twisted it back into shape and held it in a vise until cured. The repaired end is still in the car, working fine.
I had that problem on the passenger seat, seems it isn't a good idea to put the seat fully back, so my Porsche mechanic said to take a hammer to the seat, where it sits in the track, and tap it till it comes forward, seemed crazy to me, but this was the second time this had happened, so I followed his advice and it worked. Also, I was told not to put the seat fully back...it seems 911s have a tendency to get stuck when the seat is pushed fully back, never had a problem since.
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
Originally Posted by Brett - 1996 C4
You know that, I know that, problem is practically every time I take it in for service (to KNOWLEDGABLE Porsche places), the wrench puts the seat all the way back and it gets stuck. ![grr](https://rennlist.com/forums/graemlins/cussing.gif)
majority of people adjusting the seats all the way back ADD THAT LITTLE EXTRA PUSH as if they're in labour.
None-the-less, the seats tend to get stuck when the engine is not running.
if you're adjusting the seats with the engine off, the movement gets slower and slower swiftly, as if its draining the battery. And the witty try to push with their legs to accompany the motors . . . . till it gets stuck
