what is a major vs annual service and when?
I have a favor to ask. Can someone send a list of what Porsche recommends an annual service (993 of course) and what they recommend for a "major" i.e. at 30,000. If possible the intervals would also be much appreciated. I would look in my own service manual but no longer have my car so can't.
thanks,
thanks,
At my shop we like to do a "major" service every 30k miles on 993s. This involves all fluids (engine oil, gear oil, brake fluid) and all filters (both oil filters, air, fuel), and spark plugs. We also check the compression and of course give the car a thorough inspection. 993s have hydraulic lifters so no valve adjustment is needed. A minor service would be every 7500 miles since all 993s use Mobil 1 synthetic, or every year whichever comes first. We also put in Swepco 503 fuel additive at every minor service and BG 44k at every major. This stuff actually does work, never seen a regular customer car w/ clogged injectors or excessive carbon buildup. Things like belts and P/S hoses and ignition wires are done as needed. Hope this helps.
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
Chris: Could you elaborate on the swepco 503 fuel additive and bg 44k??
Chris: What is your opinion about wires, caps and rotors? SAI valve?
As for the SAI valve, there are many, many threads on the forum that deal w/ the SAI issues, do yourself a favor and do a search, b/c although I want to help you I do not want to start another 10page SAI/CEL argument thread, here are a couple:
https://rennlist.com/forums/993-forum/294270-oh-no-not-again-sai-question.html
https://rennlist.com/forums/993-forum/289639-valve-guides-nightmare-waiting-to-happen.html
But, I will say that we have a 993 in the shop right now, it has a CEL on for 02 sensor codes (a different shop took this to mean automatically replace all 4 o2 sensors!
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
Chris Andropoulos
Schneider Autohaus
Santa Barbara, CA
