HELP!!! I am freaking out about my oil level...
#32
Originally Posted by jnor10
When this is established, add oil, note where it is on the dipstick, then reset odometer to zero.
This may cause an increase in odometer gear replacement DIYs.......
Andreas
#34
Originally Posted by Dudley
Only thing tougher than reading the dipstick is photographing it.
#36
Just for fun, there have been 100 threads, including 2324 replys and 74886 views, on the subject of "oil level" since October 13, 2005. That is only 10 months ago. Soon we will have covered this subject completely.
I remember the old days of just checking the oil with a straightforward glimpse of the diptick. 100 threads later and we are all still thoroughly confused. Maybe we should just consult a psychic instead of reading tea leaves on the fluted spiral of the stick, let alone trying to reference the random number generator oil level guage. No wonder they deleted the stick on the 997. Goodness gracious.
#37
Originally Posted by JasonAndreas
Could someone post a close-up photo of the end of their dipstick next to a tape measure showing about 150mm?
So if your in the middle of the dip stick spiral, does that mean the oil is half empty or half full?
#39
If I am looking at the photo correctly the distance/range of 90mm lines up exactly with the marked 964 dipstick which matches the 0-180 Ohm range of the gauge and level sensor exactly.
One last question, is **** retentive hyphenated?
#40
Read the manual, I was confused too, asked a Porsche Master mechanic and expert on 911 and he said use the dials, not the dipstick and that is not the first time he told me that, but I too didn't want to believe in the dials...so I re-read the manual and followed the instructions correctly, car must be on level ground, proper temp for engine, temp gauge at 9:00 , etc...dials worked like a charm when I followed the manual, the manual uses the dipstick approach second, first choice is the dials.
#41
If I could see the gauge working, it would inspire confidence. I suppose I could keep adding oil, but I'm dead center on the dipstick. Is it worth overfilling to see a needle move?
#42
How many points of failure for the gauge? Sender, wiring, gauge itself, others? How many for the dipstick? If I could see the gauge working, it would inspire confidence. I suppose I could keep adding oil, but I'm dead center on the dipstick. Is it worth overfilling to see a needle move?
Could be your inability to understand and follow the manual correctly? A user error?
why would you follow an expert's advice and the manufacturer's advice over something you read on the internet? Doesn't make sense to me...
#44
Hawk,
Your advise is contrary to everyones here, although I respect the advise from that mechanic.
It's just concerning because my guage typically stays in the Red and my dipstick is near the 1/2 point. My guage occassionaly comes up to the mid point despite the dipstick. The dipstick seems the only measure that has a consistent reading. Often wondered if my "sender" or other is faulty, that's why I stuck to the dipstick.
#45
Originally Posted by Ty Smith
Hawk,
