993 Forum 1995-1998
Electrical gremlins?
Old Aug 22, 2006 | 08:08 PM
gordo993's Avatar
gordo993
Default Electrical gremlins?
Strange events while driving the other day. I was accelerating full throttle in third gear and @ 6200 rpm, I felt a stumble. It resembled hitting the rev-limiter. I was close to home and was not able to replicate. When I got home and pulled into the driveway, I noticed that while @ idle, my oil pressure was pegged high. Also, my fuel gauge had not moved off of 1/2 tank after a 1.5 hour mix highway/sidestreet driving including some spirited driving. I accelerated to approx 2500 rpm while in neutral for a second, and once it returned to idle, the pressure dropped as normal. What would cause my gauges to go goofy?
Old Aug 23, 2006 | 02:12 AM
gordo993's Avatar
gordo993
Anyone?
Old Aug 23, 2006 | 03:08 AM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Gordo:
This sounds like a system issue and that can be:
1) Failing voltage regulator
2) Bad grounds: battery, transmission, alternator
3) Failing alternator
Old Aug 23, 2006 | 08:44 PM
gordo993's Avatar
gordo993
Thanks, Steve
I'll go from there!
