Air bag warning light help!
Deer Slayer
Hi,
I earlier posted a question on erasing an error code on an OBD1 car (1995). Here's why.
Earlier today I was tooling around and my Porsche stereo cut out (no power). I checked the fuse box and the fuse was loose and wiggly. So I replaced it (old 928 trick: even if a fuse seems fine, replacing them sometimes exorcises gremlins) . Then I checked all my other fuses too, found some other wiggly ones, and replaced those.
When I restarted the car, the stereo was fine, but I had no gauges. Loose fuse... so I turned off the car, redid it, restarted the car, and the gauges worked. HOWEVER: the air bag warning light came on, going off after 2 minutes. It does this repeatedly.
Adrian Streather's book says that an air bag light that goes off after 2 minutes indicates a non-critical fault-- one that does not compromise the function of the air bag. (I timed the interval: 1 minute 58 seconds).
I then did the trick where you can read the faults by turning the key to the "On" position and depressing the pedal. The system came back with the no-fault code. Adrian's book also says an air bag fault code will persist until it is cleared. I tried unhooking the battery, but the air bag light still comes on for ~2 minutes.
My hypothesis is that the bad power to the gauges (or the other fuses I pulled and reinstalled) caused the air bag system to throw a fault, which the system recognizes as non-critical, but which I cannot now clear. In other words, there was a momentary fault, now corrected, but thhe code is persisting. OR, I genuinely have a problem (heavens forfend).
What do people think? Anybody experience this before? I am thinking, since the code-check trick comes back empty, that the air bag system has its own code storage system that I'm not accessing with the flashing light trick.
How do I access the bad code, or clear it? Is there a Porsche dealership in my future? I plan to drive it (cautiously, assuming for safety's sake I have no bag), since the bag should still function, but I would feel a lot better if the light wasn't coming on at all.
Thanks.
Thanks.
The ODB scanner won't remove the airbad check light, only the hammer tool can reset that light.
Stealer charged me $50 to reset mine after I changed my steering wheel without disconnecting the battery first.
Deer Slayer
Thanks. That's a useful tidbit, that.
Originally Posted by Thaddeus
A-ha! So there was not a true fault with your car, just a persistent code that could not be cleared, caused by a power thing, eh?
My light stays on all the time. It was on when I got the car, and the shop that did the PPI ceared it without charging separately for that. It came on again a few weeks later. The next time I take it in for service, I'm gonna ask them to clear it again. From reading rennlist, it seems that the airbag system is fine and will work in a crash, but the fault code causes the light to trip.
Technical Guru
Mine is on all the time. I got it on a diagnostic (iScan) and couldn't even connect to the airbag unit. Since then I've replaced the control unit and now the scanner says that I have power supply failure to igniter 1 & 2. Sound definitely crash relevant :-/
Anyone know what's best to check next?
