9 or 10 quarts of oil for an oil change?
I am thinking 10 quarts is about right if you don't replace the small oil filter and do not remove the oil return line. Quicky dealer service?
[QUOTE=911C2}
1 How do you get the small oil filter out w/o removing the cooler line just below it.
[/QUOTE]
Can't be done with a Tip, but very easy to remove the small filter with a manual transmission.
[QUOTE=911C2}
[/QUOTE]
The oil cooler return line sits just bellow the small oil filter. I have a hard time getting the oil filter wrench and extension on it and then pulling the filter out with the line in place. I do feel better about draining the cooler oil as well. I add almost 12 quarts when I'm done.
I check how much is drained and add about 1/2 quart more for filters. Get engine hot, check and add if necessary. I usually run 1/2 from full just to avoid overfill. Bottom line, I usually add 10 or 11 quarts.
