993 Forum 1995-1998
CDR-210 into a '95?
Old 08-20-2006, 11:14 AM
David in LA
David in LA's Avatar
Originally Posted by geolab
...I settled for the Becker Traffic Pro High Speed 7820 (was $2000 new, $450 now in some clearance stores) . Not the most powerfull in the market, but one of the clearest sounds due to its ultra-low THD (distortion).
Best is that it comes with a built-in GPS and Aux connect for Ipod or my Nokia N91 (mp3)
With the clear sound, I installed a Nakamichi amp PA504 50watts RMS x 4. Also one of the lowest THD amp on the market. (was $1600 new, +/- $200 ebay)
In the cabin, I replaced the carton nokias with infinity perfect up-front, and Kappa in the back. Cosmetically, you cannot see the difference from the original install.
For the sub, the blaupunkt odsb 5000 is one of the slimmest ACTIVE-built-in Amp sub on the market. It pumps 100 watts, and cost $100. It slips right under the passenger seat, and you forget it. 30 x 21 x 8 cms . . .
Thanks for the details. I also picked up a TrafficPro at the closeout price to use as the basis of a stereo upgrade. Still need to decide on speakers and amp, and your subwoofer solution is a nice alternative to the Rod Birch sub enclosures. Thanks again
Old 08-20-2006, 11:30 AM
Dudley
Dudley's Avatar
Mike, If I remember correctly, the Becker radios are not plug 'n play with the Pioneer Version CR-1 that we find in our MY95s. The CDCs are different animals as well.
I slightly modified the harness in my car when I installed my Traffic Pro (a Becker 220 chassis) a couple years ago. I don't have my file handy but I will check it out next week if you are interested.
Old 08-20-2006, 12:41 PM
nile13
nile13's Avatar
I'll be getting my CDR-210 here in a bout a week. We'll see how it plugs and what is needed. David, I might need to pick your brain on it by then.
How do people take CR-1 out? Do we need special tools? Or a $6 bent wire universal Scosche tool from WalMart would do?
Old 08-20-2006, 02:46 PM
Dudley
Dudley's Avatar
Mike, you can get the German radio remove tools, they are shaped like blunt Exacto blades. There is a little pin of either side of the chassis that has to be held in the center before you can push the radio out from the back. I used a jewelers scew driver the first time and it worked fine.
The TP came with a VW harness adapter but it there were a coulple leads reversed in the Porsche harness. Lot of good applicable info under "Traffic Pro".
Check this thread
https://rennlist.com/forums/showthre...highlight=cr-1
Old 08-26-2006, 01:07 PM
polver
polver's Avatar
Will the speed control for the spoiler work as the speed input to a CDR-210 stereo? I have a 1995, it did not have speed control with the original CR-1. The chasis doesn't have a wire going to the applicable pin. Can I just tap the spoiler wire and connect it to the chasis?
Dave
P.S. I may be dense if already explained) and not good at searching archives (I tried), but do I need to tap something for LCD illumination for the CDR-210 from a 1995 originally with CR-1?
Old 09-03-2006, 05:27 PM
polver
polver's Avatar
Tickling this post to see if anyone can help me.
Dave
Old 09-03-2006, 08:16 PM
geolab
geolab's Avatar
I went to porsche and got this for you
Old 09-03-2006, 08:23 PM
Dudley
Dudley's Avatar
Hi Polver.
Yes you can tap the speed wire at the spoiler. One place to grab the illumination wire is the light for the ashtray.
Old 09-03-2006, 08:33 PM
nile13
nile13's Avatar
Geolab, thanks! That's very neat. It appears that I have a newer CDR-210, so I should be able to have the illumination available.
Now, I need to look at my connectors and see if I have to find the right size female flat plug to insert into the plastic connector.
Old 09-03-2006, 08:36 PM
geolab
geolab's Avatar
if not , i can send it from paris, no prob
Old 09-03-2006, 11:49 PM
nile13
nile13's Avatar
Geolab, thanks, but it would be an overkill
However, if you tell me the right size and brand name, it'll make it easier to find.
Old 09-04-2006, 08:45 AM
Dudley
Dudley's Avatar
I read Geolab's message off a Blackberry and I could not see the PDF. That is the bomb. I also ran my reverse signal from the CEB but I have a Tip.
Old 09-04-2006, 01:08 PM
polver
polver's Avatar
Thanks, Geolab & Dudley.
It seems from the .pdf file that this is for 1996 993s and later. I have a 1995. Can anyone confirm it will still work as explained? Seems like illumination is a no brainer (since it can be tapped from the ashtray light wire). Also, if my CDR-210 has GAL in the menu, is that sufficient to confirm it is the new software? I don't recall what the manufacture date is (and I don't have the tools to remove it). I will have to get the tools to complete this mod. I bummed them off a local shop when I lived in Kansas City!
Old 09-04-2006, 02:32 PM
nile13
nile13's Avatar
Dave, what do you mean by reverse signal?
And also, what connector did you use for the illumination?
Once I fish out my car from teh shop I might make an appointement to stop by
Old 09-04-2006, 03:58 PM
Dudley
Dudley's Avatar
Mike, I installed a Trafffic Pro Nav unit. Same chassis as the cdr210/220. I soldered a splice in the ashtray light wire
Quick Reply: CDR-210 into a '95?
