993 Forum 1995-1998
"cone rash" help
Old Aug 11, 2006 | 01:57 PM
trojanman's Avatar
trojanman
Default "cone rash" help
I just did my first Auto X this past weekend (TONS of fun... I'm addicted), except I murdered a few cones with my passenger side stone guard and the "scuff" marks don't seem to want to come off.
Any suggestions or are these just the first "notches on my belt"?
Thanks in advance.
Old Aug 11, 2006 | 03:03 PM
ppressle's Avatar
ppressle
Turtle wax (cleaner wax) seems to dissolve the cone rubs on the paint pretty well. Wax and grease remover (bug and tar remover?) will do it as well but is a bit more agressive. Be sure to wax afterwards if you try that.
Pete
Old Aug 11, 2006 | 03:06 PM
touf's Avatar
touf
Jeff, I use goo gone to remove the rubber from the cones.
After u use goo gone, make sure u apply some wax where u used the goo gone since it wil also remove wax.
Old Aug 11, 2006 | 03:26 PM
Mark in Baltimore's Avatar
Mark in Baltimore
If Goo Gone is the same product as Goof Off, be very careful with it around the paint finish, as it may cloud your finish. Ask me how I know...
Old Aug 12, 2006 | 03:46 AM
c993k's Avatar
c993k
Mark just said what I was thinking. I never trust strong chems as removers. Use a mild rubbing compound and be safe. Wax right after. Chris
Old Aug 12, 2006 | 04:34 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
WD40 works well. Just be sure to degrease and re-wax the area.
Nice seeing you out there Jeff!!
Old Aug 12, 2006 | 04:46 PM
Don Plumley's Avatar
Don Plumley
The new bug and tar remover (looks like lotion) is great for tire marks and cone rubs.
Old Aug 12, 2006 | 11:19 PM
TMc993's Avatar
TMc993
H-m-m-m-m-m...Sure are a lot of folks here that know about hitting cones. I thought the object was to MISS the cones!
Just joking guys...I've hit a few myself.
TMc
Old Aug 12, 2006 | 11:38 PM
Mark in Baltimore
One more thing: try using Meguiar's Finesse Cleaner. I've been using to to remove rubber marks from tire debris at the track and find that it works very well. I also used it to bring the life back to a badly oxidized finish on my red 1990 Miata.
Old Aug 13, 2006 | 01:58 AM
trojanman's Avatar
trojanman
thanks for all the input... I'll try a few suggestions and let you know how it turns out.
And Chris, good seeing you too... and nice driving!
Old Aug 13, 2006 | 08:35 PM
993Brendan's Avatar
993Brendan
I use McGuires Bug and Tar Remover- it works great for cone streaks, rubber tire marks from the track and, of course, bugs and tar.
Old Aug 14, 2006 | 09:38 AM
Blue S2's Avatar
Blue S2
I recommend the 3M painters tape! Its the blue rolls. You can get it on ebay for insanely cheap. Take 5 minutes and put a little on prone areas. Then you can go have a blast and not worry about hitting a cone. I noticed once I didn't have to worry about a scratch, my driving got a lot better too!
Old Aug 14, 2006 | 10:00 AM
amfp's Avatar
amfp
Another option is to try Plexus. If need to get more aggressive use a citrix cleaner like Wurth. Last option is a cleaner like 3M and put a dab of Blue Magic on cotton towel. Do not circular rub. After done use a wax without silicone, like P21, or Blitz.
