Cabriolet (1995) Top won't open: fixes?
Without any warning, my 1995 Cabriolet's top won't open.
I pushed the down (open) switch, the top-in-motion light came on and I heard the motors make some effort, but then the top didn't open. I pushed the up (close) button and light didn't go out, either.
Somewhere I remember a discussion about how to manually open the top (okay, I remember that it is discussed in the owner's manual, but that's not the one I believe I'm rembering).
It even had pictures showing the related motors and gears and how to fix them.
I've searched here, looked at p-car's DIY section, looked at 993faq.com, with no success.
Anyone out there know of any online fixes for this?
Or should I just have a mechanic look at it?
oh oh it maybe time for new cables . I just replace both and while at it change the rag top and enjoying summer . Actually changing the cables is easy DIY with this link http://p-car.com/diy/cabtop/
hope no rain in your forecast but you can just loosen the bolts on both side and lift the top manually
Which motors did you heard? The latch motors in the front of the top or the lifter motor behind the rear seats? If the latch motors didn't reach their end positions the lifter motor do not
begin to move.
Did you notice the recall from Porsche for this latch motors?
PDriver
begin to move.
PDriver
begin to move.
PDriver
begin to move.
PDriver
I believe the motors I heard were the front ones.
briefescape, thanks for the link!
When were the recall done? Isn't there a warranty for new parts?
Seems to me, that they installed the new motors not correct or didn't
realigned the top after installing.
PDriver
PDriver
briefescape,
you said that you changed your ragtop? how much work was it, I had heard you have to glue it to the front? did you take any pics? 1-10 how was it? (obvoiusly I need a new top)
When the motor won't come on (or comes on and then stops working and then works again the next time you try it) it may be cold solder joints in the top control unit. There is a thread on that somewhere.
When the back motor is working, but the top isn't moving, it's generally cables. If the front latch motor is running, but it isn't unlatching, I haven't run into that.
The front latch motor may have started to operate and then quit due to a faulty top control unit that sends the signal to the front latch motors. The back motor won't come on until the front is unlatched.
A couple of years ago I had a probem with my top where when I pressed the switch to open or close it, nothing would happen. It turned out to be a cold solder joint in the control unit. I did a write up on how I fixed it. I don't know how to post the link so do a search on "problem solved". Have'nt had a problem since.
Good luck,
Shawn
Good luck,
Shawn
Good luck,
Shawn
Good luck,
Shawn
Now if I could just figure out where the thing is located under the dash. Fixing it myself once I get access to it should be no problem. I've soldered a lot, being an ex-electrical engineer. And a $0 fix is rather attractive now.
Can you give me more information about where this thing is buried?
PDriver's reply prompts me to ask... Has any curious person (curious, as in smart) drawn up a "simple" flowchart of the logic followed by the roof system? I've always wondered what the sequence was ever since I drove around with the roof warning light on even though the roof was securely latched in place (went away after the recall fix). I find these are priceless when it comes to troubleshooting.
Sorry to be "asking" not "helping". Good luck Jim.
I think I've got the flow somewhere, but I'll have to scan it, if I find it.
Shawn's expertise in this area really shines in his post, but to answer your question, if you're lying on your back in the driver footwell, with your head under the dash, you should see a silver control unit to the right of the steering col. Remove that, and the top control is attached there.
Originally Posted by JimProuty
...Can you give me more information about where this thing is buried?
Originally Posted by TheOtherEric
To add to the other comments, to get this out, you'll need to attach a 10mm socket to a universal joint to a screwdriver. Otherwise it's very difficult since you dont' have a straight shot.
With all these pointers, I'm going to owe everyone a beer!
