Plug Wires Mixed
I have done a little research and discoved that my pulg wires appear to be a little mixed up and wondered what the correct order is. or I would just comfromation this is the correct setup. I noticed that my upper plug wires went to the bottom distributor and the lower ones went to the upper cap. Car seemed to run fine but i have noticed a slight midrange hesatation ( that is what caused me to look at them ) I have read that the upper wires should go to the upper cap and the lower ones to the lower cap, is this correct? does it matter which coil is connected to which cap? the wire ordering appers to be correct. any help is apperciated.
Upper to upper, lower to lower. Can't imagine that it would make any difference though I may be corrected on that. I'm suprised that they reach - I remember mine being pretty hard to fit wrong as they were fairly precise lengths.
-- Chris
-- Chris
