Oil-0W-40 or 15w-50 Mobil 1
I bought up all that Walmart had (17 quarts). Every time I go in I look for it, because they rarely have it in stock. I am only using 15W-50. 0W-40 could be useful in very cold climates, but in So Cal cold is 40F. Some have reported ticking lifters with the 0W-40 that goes away when using 15W-50. The thinner 0W-40 may not allow enough pressure to be produced at idle (oil temp should be ~9 o'clock and pressure should be ~2 bar). At 2500 rpm pressure should be 5+ bar.
fwiw: i think 0w 40... grey cap is what the 'stealer' uses.... but of course charges gold cap+ prices. ![Stick Out Tongue](https://rennlist.com/forums/images/smilies/tongue.gif)
in the past i've have had the 'tic' when runnin' it (start ups in the socal mornings esp.)... when 'cold' -go figure.
no mas por mi.
no mas por mi.
In lieu of 15W-50, use 5W-50: the '15W' or '5W' refers to the viscosity index when the oil is at ~ ambient temp. When the oil is up to the core temp of a warmed engine, '50' is the operating viscosity.
There is no discernable difference in the two when warm. I think Mobile I is now producing the 5W-50, and Castrol have been doing so for some time.
