Motor Sound Air Box & Snorkel
I have the flame suit on so I'm prepared but I need to ask a simple question... I just got the factory snorkel from Gert and I'm about to install my RS tail but I have a quick question. Do I need to change the airbox cover from the motor sound airbox or do I simply remove the chrome extension on the motor sound box? It looks like you can pry it out and replace it with the snorkel. The chrome extension seems to have three or four tabs that will allow this piece to be released... No?
Thanks,
Jon
Thanks,
Jon
To be honest the sound diffrence comes from the Motor Sound airbox itself and the mufflers. The high rise intake probably pulls cooler air. As far as a difference in sound I did not hear a difference
First off if you do the cold air intake you will need a RS tail ot TT tail to make it work. If you have the movable spoiler the intake will not work because it sits above the decklid line. It does face upwards (toward the sky). There are 2 drain holes in the bottom of the intake that allow water to drain.
Mike
Mike
Thanks Mike. My car is equipped with a Gemballa Rear Wing. I'm just wondering whether those two holes are enough to drain all the water from heavy rain and to keep the water off the air intake.
I was running a Cup Airbox but after reading some negative feedback on it, I switched back to OEM Airbox now.
The part number of the trumpet is 993.110.360.51 right?
I've followed the threads about intake temp closely and made the decision to go with a trumpet for cooler air intake, and get my "rumble" from a different exhaust.
I ordered a trumpet fron Sunset about a week ago - they said it had to be imported first.
I'm just amazed at the increase in engine sounds I'm hearing with the Gemballa wing installed.
